2009 SS Cooling Fan Pigtail/Connector
Old Aug 2, 2022 | 02:41 PM
gravator's Avatar
EDIT: I thought you ordered the Aptiv 480. The one on eBay, the locking clip looks just a little wider than the original, almost as wide as the male part of the connector. The dimensions they give, the length and width match, but the height of my connector is about 27.5 mm, their connector is 24.8. Significant
That was what I am unsure about. It says it is using the Metri-Pack Series 480 which should be just like this other one (Aptiv) I linked too. Hopefully their measurements are listed incorrect.
Old Aug 3, 2022 | 03:47 AM
rorr's Avatar
The GM service manual will have the part number and specs of each connector, if someone has access (my server is down right now, or I'd look).
Mouser is a great source (mouser.com) for components. Doing a quick search, this could be the one:
https://www.mouser.com/ProductDetail...lDyvHe8w%3D%3D
I've ordered from them before and it was painless.
I may be able to get my server back online this weekend, if that would help.
Also, don't discount there may be something more wrong that caused the connector to melt. Or, it could've just been a poor connection...
Robert
Old Aug 3, 2022 | 07:53 AM
This is what Mitchell says:
Old Aug 3, 2022 | 01:38 PM
rorr's Avatar
That looks different... For some reason.
I just realized the link doesn't work in my previous post. Just go to Mouser and search for part number 12124388.
Sincerely,
Robert
Old Aug 3, 2022 | 02:44 PM
That's must be the other connector, from the harness to the module. We're talking about the fan to the module.
Old Aug 3, 2022 | 06:35 PM
  #26
Mitchell only has the one that I could find. Maybe it is considered part of the fan? GM considers the shroud, fan and module an assembly.
Old Aug 3, 2022 | 07:16 PM
  #27
It would have been nice if it was the same, so one could bypass the module, as a test.
Old Aug 4, 2022 | 10:38 AM
  #28
gravator's Avatar
Sincerely,
Robert
Yep that is the 480 we were discussing and linking too above(only from another vendor). Mine should be in tomorrow or Monday and I will share what I find.
Old Aug 4, 2022 | 11:11 AM
  #29
The module is probably just a MosFET and the "relay control signal" is PWM. So, bypassing the module, fan directly to the control wire probably would not work. Running 12V and ground to the fan should work.
If it is a MosFET, that explains how they fail. They are very sensitive to things like reverse voltage and stray static. Plus they can get very hot without proper heat sinking.
Old Aug 8, 2022 | 12:45 PM
  #30
gravator's Avatar
Here is the eBay one vs original one. The eBay one is a little bit smaller on plastic around connector. See picture. I am going to see if this will work tonight some how and report back. I think I can get it to work if I move the green seal from old to overlap the red seal on new one.
