2009 SS just died - please help!
I was driving to church this morning when the car suddenly had no power at all. I was able to pull to the side of the road. I looked at the dash and the oil light flashed on, but went away. I tried to restart and it would run for a few seconds roughly then shut off. Then would not restart. If I wait a few minutes it will restart again and run roughly for a few seconds and cut off again. Luckily I was at a place where someone had an OBD reader and said it was fuel pressure problem. I had to have it towed home. I currently have 12500 miles on her and drove over 750 miles in the last 2 weeks with no indication of problems.
Any ideas? Would it be a clogged fuel filter or what?
I am going to call a local dealership and see if I can have it towed in for service tomorrow. It should be under warranty since it is bone stock and has so few miles. I would like to know what to tell them before I go there.
It almost seems like the fuel filter might be clogged. It will start up after a while and run for a few seconds then quit. It is like the clog comes loose and the flow comes back but once the pump kicks in it reclogs the fuel line. Possible?
No filter in these from what I've read.......
