any one with lsd
Old Nov 17, 2010 | 01:24 PM
JJ's BLACK SS's Avatar
any one with lsd
i am just wondering i have never heard this befor but when i am turning i hear a clicking sound from the frontend. has any one heard this before
Old Nov 17, 2010 | 09:14 PM
Sidecardog1's Avatar
JJ, I have a '10 with the 5spd, lsd, Brembo and the power upgrade on mine. 14,000 miles and I do not hear the clicking from the front end. Are you sure it is the front end and not the high pressure fuel pump sound? The fuel pump sound is more pronounced when the motor is first started up. If the pump is not the source of the clicking and it is metallic in sound, I would think you have a problem. Could be something as simple as a brake pad anti rattle clip that has moved out of position.
Old Nov 17, 2010 | 09:57 PM
Father Azmodius's Avatar
My LSD doesn't make any noises that I can discern. A clicking noise while turning would lead me to think CV joints. Of course, with out hearing it in person, I wouldn't say for sure that's the issue. How many miles do you have on it?
Old Nov 18, 2010 | 07:13 AM
bartSS's Avatar
My first guess is that its ur CV joints as well just like Father said
Old Nov 18, 2010 | 07:58 AM
camaro98z28's Avatar
I see and hear all kinds of things when I'm on LSD. LOL J/K
Old Nov 18, 2010 | 01:11 PM
i know what the fuel pump sounds like it isnt it. i only hear it when i am moving and turning, not when driving. i guess it is time for a dealer visit
Old Nov 18, 2010 | 01:12 PM
and i have 8k on it now
Old Nov 18, 2010 | 02:43 PM
jeffros hhr's Avatar
Sounds like what I'm dealing with today.It's progressively gotten louder and I believe it's the bearings going out.Mine also sounds worse when you're turning a corner and sounds like loud road noise from tires when driving.Been told you have to replace whole hub assembly,can't just do bearings like you used to on the older stuff.Alot more friggin' expensive too !! About $180 for the assembly from Advance Auto parts.Sounds like either that or a CV joint.
Old Nov 20, 2010 | 10:45 AM
rdnck1's Avatar
Could be your sway bar bushings, they have a tendancy to wear quickly for some odd reason... clicking also leads you to believe it could be the cv joints or half shafts... I have lsd on mine and the bushings are starting to wear and making a similar noise.
