Anyone know the size (12 or 15mm?) of our exhaust hangers?
I just had my Hahn kit put in and it seems to be sagging a bit. I would like to replace the stock rubber mounts with some urethane ones. It appears that they easily come in 3 sizes, 9mm, 12mm and 15mm. Any idea which size? I poked around and it seems like 15mm is the right size? Thanks!
Brian
Brian
Later
Allex
The 12mm I received are way too small. 15mm must be the correct size...
I drilled them out to give them a larger opening. However, they are not fitting as snug (on the exhaust side, not car hanger) as I would like. I may end up just ordering the larger ones now.
Can you take a picture of them? Were these universal hangers, or did you find a Kartboy set on EBay? I just received my Kartboy set and will install them later today. I'll take a picture of them and upload them later; on my phone now so it'll be a while before I upload them here..
Later
Allex
Later
Allex
