Apparatus Bolted to Intercooler
Old Apr 3, 2019 | 08:31 AM
m_ridzon's Avatar
I took off my OEM intercooler to do some work. I noticed some additional apparatus bolted to the bottom of it. See the attached pictures. Does anybody have an idea of what this is? The intercooler's job is very simple; i.e., exchange heat with the environment. So I'm confused what the additional apparatus might do.
Thanks in advance!
M Ridzon
Old Apr 3, 2019 | 09:41 AM
Not sure.
My 1st guess would be some type of moisture extractor chamber.
2nd guess is a type of muffler to diffuse turbulent air flow inside the intercooler.
Someone must know the answer. ( I bet DrLoch knows )
Old Apr 3, 2019 | 01:29 PM
Cat Man HHR's Avatar
This is a good one. #3 on this GM parts blow up shows a mounting bracket. It's on the back side of the inter-cooler.
https://www.gmpartsonline.net/auto-p...tercooler-scat
Why would this be on the back and hinder air flow ?
The back of the OEM unit doesn't look too good to begin with.
Old Apr 3, 2019 | 01:37 PM
m_ridzon's Avatar
#3 in your link is not the part I'm referring to. The part I'm referring to is not specifically shown in that image. Rather, it's part of #1, the intercooler, and attaches to the bottom of it. But again, it's not shown in the exploded view you linked to, probably because the two pieces are sold as a unit.
Old Apr 3, 2019 | 01:49 PM
Your correct, I was looking at it all wrong.
"Stupid is what stupid does".
Old Apr 3, 2019 | 01:57 PM
m_ridzon's Avatar
Old Apr 4, 2019 | 12:54 AM
Pretzel's Avatar
FiremanGeorge is correct.
Its a moisture/oil trap. A lot of Cobalt guys were snapping them off by rough driving.
As said on the Cobalt forum:
That service information is for earlier build 2007 Sosltice GXPs that when driving in damp /humid weather encounter misfires and set codes on hard acceleration. Moisture gathers in the charge air cooler at idle and is ingested on hard acceleration from a stop.
Here`s the link.
https://www.cobaltss.net/forums/08-1...n-pipe-212936/
https://www.cobaltss.net/forums/prob...ow-bad-290706/
DOH!
Old Apr 4, 2019 | 07:32 AM
m_ridzon's Avatar
Thanks for sharing @Pretzel . That makes perfect sense!
Old Apr 4, 2019 | 08:36 AM
DrLoch's Avatar
winner winner Pretzel is correct
Old Apr 4, 2019 | 09:40 AM
I noticed in their information, the ZZP intercooler doesn’t have the plastic piece.
