Auto tranny strong enough for stage 1?
Old Jun 10, 2009 | 09:52 AM
Mowgli's Avatar
Originally Posted by Lars on Live
pretty sure the brembos and LSD option is only available with a manual.
Local dealer just comfirmed that you are correct, sir.
Old Jun 10, 2009 | 10:02 AM
Mowgli's Avatar
Originally Posted by More_Torque_More_HP
Here are the production ratings of the LNF engine. Torque curves are very flat
HHR SS automatic 250 hp @ 5900 222 lb-ft @ 1650
HHR SS manual 260 hp @ 5300 260 lb-ft @ 2000
The stage raises the tq peak to 4800 curiouser & curiouser
Less broken drivetrain components methinks
DSM peeps bring extra trannys, transfer cases & axles to The DSM Shootout in Norwalk
Old Jun 10, 2009 | 10:12 AM
DMarotta's Avatar
I have the 08 with auto and the GM stage kit since January. 20,000 miles since the kit was installed with no tranny issues.
Old Jun 10, 2009 | 10:47 AM
gmdealerguy's Avatar
I have an 09 SS with the Stage 1 kit. Had the kit for the last month. I too wonder about the tranny strentgh. I worked as a Parts Manager for 23 years in a Chevy dealer and I know that GM trannys(stock) are not very strong to begin with. I worry but whatever happens...happens. It's under warranty. I guess those of us who have it already will be guinea pigs.....meaning we will just see if it holds up as we go along.
I dont push mine too much,such as nailing it off the line at every light but I do lay into it alot once I am already going. So far so good.
Old Jun 10, 2009 | 11:09 AM
SSROADSTER's Avatar
BSR HAHN Tune w/Auto
had this tune since 9000 miles, now aproaching 28,000 miles, more TQ & HP than the Stage 1 GM tune, no problems at all with the auto trans, in fact the trans even responds better in the Comp/Laaunch Control mode. I know I gave up the warranty on the drive train if something goes wrong, but then again I don't beat up on it, so I do expect it to last for a long, long time.....
I would never go back to stock, in fact I have a spare ECM, that I am thinking about using with the Superchips tuner, as I had one of these in my 04 GTO which was unreal......that gives you a little more tuning ability than the BSR......so we shall see
Old Jun 10, 2009 | 12:15 PM
jerSSey HHR's Avatar
This begs the question why Chevy detuned the auto down from 260 HP, if they allow the Stage 1 kit to boost it up to 290 HP.
Old Jun 10, 2009 | 12:34 PM
stephenm's Avatar
So they can sell the stage kit.
Also the owner of a local tranny shop told me that the auto trans is fine for a cavalier. Gm may have hardened the input shaft but the differential is what he would be worried about. If the diff grenades it will wipe out the whole auto trans.
The warranty with the stage kit adds some comfort though
Old Jun 10, 2009 | 12:43 PM
Mowgli's Avatar
Sounds about right.
BTW - Stephen - your computer has airbags & a roof?
That must be one fast & drafty computer
2008 IBM SS
AT, Roof, Side Airbags
edit - hahaha Imperial Blue Metallic, IBM SS didn't show up on Google hahaha
Old Jun 10, 2009 | 03:15 PM
Originally Posted by Mowgli
Sounds about right.
Well, IBM is known as BIG BLUE!
Old Jun 10, 2009 | 11:22 PM
IgottaWoody's Avatar
The Solstice gets a higher rating because of the rear wheel drive, it covers parasidic loses from the extra driveline....so it should equal out about the same...just get it, you won't be sorry
