Auto Transmission Fluid Level Erratic
Old Mar 13, 2024 | 05:38 PM
Waynejwj's Avatar
I have an interesting situation. I am having shifting problems with a 2009 SS automatic. I checked the fluid level by GM guidelines. The transmission had about a quart of fluid to drain before it stopped. After waiting a few minutes I wanted to see how much fluid it would take to start dripping from the hole. I added one quarter quart back to the transmission and the fluid would not drain. I again added one quarter quart and the fluid drained out just a little less than one quarter quart before it stopped and just dripped out. This does not make sense to me? I had the shift solenoids replaced five years ago. I do not understand how this was possible. The car was running and not moved during this process and was level. The fluid was nice and clean looking with no trash.
Old Mar 14, 2024 | 06:49 AM
Running at idle? In park ? Warmed up? Or cold then warmed?
Old Mar 14, 2024 | 07:46 AM
It is supposed to be checked warm engine running in park. Not running the fluid will be high.
Old Mar 14, 2024 | 09:00 AM
And with the vehicle level.
Old Mar 14, 2024 | 10:49 AM
He says he checked the fluid while engine running not moving and level.
Old Mar 14, 2024 | 08:17 PM
If you pulled the plug with the engine off about a quart would flow out.
Old Mar 14, 2024 | 08:59 PM
Did we miss something? I don't see that.
Old Mar 15, 2024 | 07:19 AM
see the sentences……………………………^^^^^^ up there second row up
Old Mar 17, 2024 | 03:08 PM
Waynejwj's Avatar
The vehicle was running in park, level and the trans temp was 120 degrees.
Old Mar 17, 2024 | 05:30 PM
It is obviously Space Aliens.
MJR1970
Maintenance and Upkeep
Feb 26, 2023 09:40 PM
Gearhead1
Oct 25, 2021 08:15 AM
Herbie
66
Jul 7, 2014 10:52 AM
bigjacksauto
Mods - Exterior
Jan 19, 2012 10:25 PM
wgiff
Jan 26, 2011 02:44 PM
