Balance Shaft Sprocket Bolts
Old Jan 22, 2019 | 05:26 PM
I'm pretty sure I just postedf the spec in the torque thread. From Mitchel. https://www.chevyhhr.net/forums/how-...e-items-54648/
If you have 32 bit/ x86 Windows I cal help with AllData.
Old Jan 22, 2019 | 09:10 PM
Remove the retainer tabs place a drill bit in the hole to hold the gear to remove the 15 mm bolt holding the gear (sprocket) on. Re-install the new gear and torque to 37 ft-lbs. The new gear is slotted so it can only go on one way. Do not mix up the intake & exhaust balance shaft gears.
Old Jan 23, 2019 | 07:29 AM
m_ridzon's Avatar
No need. Impact buzzed it right off, with no issues.
I'm just curious on where you found this information, because I scoured but couldn't find it anywhere.
Exactly. I was careful to mark everything (including these shafts and gears) during disassembly. Not to mention, the balance shaft sprockets have notations on the front, "intake" and "exhaust." So unless you're really in the twilight zone, you can't mess it up! Haha!
Old Jan 23, 2019 | 07:31 AM
m_ridzon's Avatar
Thanks for this useful information!
Yes, I'm eager to hear whatever you can share about AllData! Is it accessible to me?
Old Jan 23, 2019 | 11:10 AM
Cobalt SS site.
UWZerokoolX
"How To" Tutorial Library
19
Sep 24, 2020 07:47 AM
d0sitmatr
Jan 30, 2019 05:36 PM
intruderdct
Drivetrain (Excluding Engine)
Apr 3, 2017 07:54 PM
PaperChaseHHR
2.2L Performance Tech
Oct 10, 2013 09:26 AM
