Boost gauge question??
Old Apr 8, 2018 | 05:51 AM
evotech's Avatar
Does anyone know for sure which MAP sensor is used for boost reference?
Old Apr 8, 2018 | 01:16 PM
Neither one directly. The ECM has some sort of AlGoreithm to compute it
Old Apr 8, 2018 | 03:34 PM
evotech's Avatar
the pressure is measured at one or both of the map sensors. Perhaps it is an average of the two. Although I would like to know for sure.
Old Apr 8, 2018 | 04:32 PM
Nothing definitive, but I just disconnected the upper and went for a drive.
Gauge still worked, vacuum down to 20", but would only boost to about 10 PSI. So I think it was still accurate, but boost was limited.
And no CEL.
Old Apr 8, 2018 | 05:02 PM
The ECU uses input from the MAF, MAPs, engine speed, ambient temp, intake temp and probably more sensors to calculate the boost and torque. Then it sends a PWM signal to the boost gauge.
You could do what RJ did and disconnect them 1 at a time to see what happens.
Old Apr 8, 2018 | 05:18 PM
evotech's Avatar
And no CEL.
thanks for doing that. It was very helpful to eliminating t one possible cause of my issue.
Old Apr 8, 2018 | 05:34 PM
You could tell us what issues you're having.
swish43
Jun 22, 2014 08:52 PM
InkTheFlesh
Nov 15, 2012 01:20 PM
agentsmith23
Jul 3, 2008 01:10 AM
