boost issue again
Old Apr 7, 2010 | 09:24 PM
IgottaWoody's Avatar
I tied my lower IC duct back away from the AC pump with a zip tye...everything normal now, for now, will get me by till I take it in....I could fix this myself but feel GM needs a history of complaints to make any improvements..maybe next time they will pay closer attention to design clearences...I think its more of a motor mount problem...too soft-too much movement
Old Apr 8, 2010 | 05:40 AM
hyperv6's Avatar
Stiffer mounts are not the answer. If these were older cars it could be wear but these are new car.
A stiffer mount would only bring more complaints of noise and viberation with a 4 cylinder. There is really not any more movement than most other cars.
The big issue is the Upgrade T map is a different angle than the stock one. The Bosch unit was originally used in a Alfa Romeo. That is why the tube needed modified.
GM tried to use an off the shelf part as they only needed a 3 bar T map. This is also why there is a change in the connector.
IF GM had to have a new T map made just for this we would have had more much cost added to the purchase price and a good chance as these get got older that replacments would not be available.
Also I think the connectors are blaimed much too often for something they are not causing. They are a very reliable part if installed properly and will last the life of the car with no issues.
Also while some blaime the connectors I think this is only true in a small number of complaints and was just due to improper use of the connectors. Most do not have a bad connetion. These connectors if used properly will overate for the life of the car with no issue.
You can figure once they are done there will be less than 10,000 SS made and only 25% or less with the upgrade. By using an off the shelf part we will not get stuck later adapting our own unit if they become hard to find. This is a common Bosh unit.
Per the GMPD teams engineers recomendation to use fender washers to move the I/C forward it solves all the issues. The gap varies with each SS and some just need that 1/8 inch to clear with this T Map.
Also how far the tube is able to be pushed on seems to be a factor. My first tube did not hit but the second one did. My first tube blew out an I only had issues once the second tube was installed.
Old Apr 8, 2010 | 11:39 AM
gcsd3742's Avatar
good answer and I still have all my factory parts, if someone needs them, I went aftermarket just because all the issues i was seeing. + the Polished stainless still looks really nice. The only issue I have had was one of the couplers became loose and blew off the turbo intake and popped up hit the hood. now I got a nice dent in the hood. But oh well all in a days playing....
Old Apr 8, 2010 | 08:36 PM
JJ's BLACK SS's Avatar
i was thinking of having secret services make a cold side pipe and rotate the sensor so that it runs with the pipe.
Old Apr 8, 2010 | 08:37 PM
gcsd3742's Avatar
All my CHIT is outta the way and it runs beautifully....
Old Apr 8, 2010 | 08:47 PM
  #26
i will talk to them next week all the sensor needs is a 45 degree rotation
Old Apr 8, 2010 | 10:32 PM
  #27
...in MY case, there is excessive engine roll over...while in low gear in slow traffic( to stay off the brakes) just a slight touch of the gas petal will thump the eng quite a bit, the same when letting off...I wasn't saying all the SS cars have this,,,just something i noticed on mine..I'm sure it still would have rubbed thru eventually with less movement as there is next to no clearence there..thats why tying the IC back temp fixed mine....but I still have a lot of rock that thumps the whole car. and after dealing with my service guy today I really don't want them touching it...my other car was in for minors and they did everything they could NOT to have to fix them....really poor service...but ...sigh..they installed the kit so...................I will try first,
Old Apr 9, 2010 | 02:15 PM
  #28
terryk's Avatar
Question
Is this to swing the intake pipe forward and away from the AC compressor and line? I've seen this suggestion elsewhere. When I look at mine, it looks like the new map will go under the line (even though the map is taller). The kit gets installed Monday so I will be able to see better how close it is.
I was thinking the lower hose could be trimmed at the IC and have the same affect if it becomes necessary.
Is it possible to rotate the map 180 degrees?
Old Apr 12, 2010 | 10:03 AM
  #29
i had mine rotated towards the radiator
Old Apr 12, 2010 | 10:52 AM
  #30
terryk's Avatar
So it fits flipped around so the connector is on the radiator/IC side?
