boost issue again
Old Apr 14, 2010 | 12:58 AM
  #31
JJ's BLACK SS's Avatar
yes
Old Apr 14, 2010 | 05:43 AM
  #32
hyperv6's Avatar
Flipping will wotk if you have the room. Not all have the room depending on the spacing of the IC.
If you don't have tool it can hit the radiator.
THis is what I was told by GMPD.
Old Apr 14, 2010 | 08:31 PM
  #33
at one time i had the room. but my motor mount is not broke like i thought.
Old Apr 20, 2010 | 02:35 PM
  #34
Rice Reaper's Avatar
boost issue
when we got our 2010, the boost went up to just a hair below 15. is that about normal? when we had the dealer power adder installed it went to just below 20, but now after 2 weeks its going to about 16.5-17. i've scheduled an appointment to check that the ecm reflash was done correctly. but where should it actually be?
Old Apr 20, 2010 | 04:06 PM
  #35
hyperv6's Avatar
Depends on your altitude.
But I would think you should see at least 20-23 psi in most areas of the 48 states.
In Ohio I see 21-24 depending on the weather.
Old Apr 20, 2010 | 04:08 PM
  #36
gcsd3742's Avatar
I see 28 settles @ 26 winter or summer.....
Old Apr 21, 2010 | 07:34 AM
  #37
More_Torque_More_HP's Avatar
If you were seeing 20 psi and did not set codes then the ECM flash was done correctly. Checking is only going to cost you time. A "reflash" won't help or fix anything.
Boost level is an outcome not a controlled parameter. The ECM commands a torque and if the weather is cooler and the air is dryer, then it takes less boost to acheive the same power output. You could also check for system leaks to because they can cause reduced boost. Check your intercooler to make sure the air passages are parellel and not "blown up like a baloon" and leaking.
Old Apr 21, 2010 | 07:38 AM
  #38
gcsd3742's Avatar
I agree but I also disagree... When I got mine reflashed the numerous of times was it 3 or 4 it ran a whole hell alot better. but maybe it was relearning, and the parameters werent set. What would it hurt for him to get it reflashed? it's free....
Old Apr 21, 2010 | 08:35 AM
  #39
It won't hurt anyting... other than warranty cost is part of the cost of buying a car so unnecessary warranty cost (all warranty cost for that matter) ends up pushing the price of the cars up. And the time it takes inconvients the customer.
The only thing a reflash does is resets all the fuel trim/learn tables to nominal. This can be done with a simple 30 second battery disconnect.
Old Apr 21, 2010 | 09:55 PM
  #40
what would happen if you put in the flash for another car like the solstice insted of a hhr tune
