Can't figure out no boost preasure
About 2 months ago I replaced the turbo because the fins stopped working and it was leaking oil and running really bad so I replaced it one from eBay I shouldn't have but it didn't have a lot of money I paid I think $160 for it with shipping so of course I know you get what you pay for and I put it on and it lasted pretty much about a month and a half and for the last two weeks I have taken the turbo off change the wastegate i have changed the Boost valve solenoid piece by the turbo housing there's no vacuum leak the car runs great it's just when I give it gas and try to rev up it'll go to zero pounds and that's it but the car runs as smooth as silk it is a 2009 sS with around 2 if anybody has any solution or tips and tricks because I have rattled my brain i tried bypassing solenoids i have vacuum the only thing I don't have is any boost whatsoever and there is not a check engine light
I've checked everything and no leaks, when at idle I have 20 vacuum on the gauge and I stomp it goes to 0 and that's it, I can hear the turbo spooiling up but no power
