CEL Two Codes P0455 & P0497
At first I thought my vent solenoid was toast but now I'm not so sure. I've already replaced my evap solenoid on the engine so I know that's not my issue.
The car seems to run fine, it's not running in limp mode and still is pulling 15lbs of boost.
It has 119k miles.
It has 119k miles.
AH HA, That's when my LT did it. Turns out it has nothing to do with my EVAP system, it was a mucked up O2 sensor. When the 2 O2 sensors agree with each other exactly you get a code thrown, that happens sometimes when you remove your foot from the gas pedal quickly.
In my case, a seafoam induction and oil treatment fixed it until I finally got the EVAP test to run. Then I replaced my post O2 sensor. My problem seems to have come from a stuck piston ring causing a quart of oil to burn in 1,000 miles gumming up the cat and sensors.
Yours could be just a vac leak under the hood.
Another instance of codes not meaning what they seem to say.
YMMV
YMMV
CDS31MC
Mar 24, 2023 09:00 PM
