Check engine light from HELL!!!!
Old Mar 25, 2012 | 12:50 PM
Tyler Harvey's Avatar
843de, you wouldn't have one for a 09 SS?
Old Mar 25, 2012 | 12:57 PM
Just the '08 Tyler, you might find them useful, but I'm not sure of all or any of the differences between the '08's and '09's.
Old Mar 27, 2012 | 08:17 PM
stryder's Avatar
still no idea whats causing it.
Old Mar 28, 2012 | 04:26 PM
I hear you Stryder, I'm going through the exact same thing. I shouldn't have used the word "grind", as it's more of a sputter noise on cold starts. Lasts only for one second. The thing is with mine, I'm not getting the "check engine light".
Old Mar 30, 2012 | 08:03 AM
stryder's Avatar
its like a clogged or dirty cat or maybe the Map sensor or the maf or something lol i can't figure it out, the wife has been wanting to trade it in for a while but doesn't want to trade it in with the CEL on. I have thought about using hp tuners to just shut off the Cels and keep them from turning on at all lol but thats kinda messed up i would rather fix it with out paying a dealership 700-900 to tell me they don't know whats wrong
Old Mar 30, 2012 | 09:06 AM
foolmoon_design's Avatar
Vacumn, O2, rough start.... I'd look at a head-gasket leak. or a crack in the vac switch under the airbox $.02
Old Apr 2, 2012 | 02:58 AM
stryder's Avatar
no crack in the head gasket, no vacuum leaks either
Old Apr 2, 2012 | 09:01 PM
Stryker, you might want to look into the fuel pump, regulator and Cat. I've got the same issue and the dealership said fuel pump.
Old Apr 2, 2012 | 11:08 PM
It could very well be, does the engine start normally, then start to stall with the onset of the clattering noise. That's what Tyler's engine was doing, it was a fuel starvation issue, as the engine "lays down" due to the low fuel pressure you get a burst of pre-ignition clatter for about two seconds then it picks up and runs normally. Does this sound like your engine stryder?
Old Apr 14, 2012 | 09:36 AM
I hope he's doing okay Mike? Curious, to see what his problem was.
