Dejon Powerhouse Wastegate Spring
Old Jul 16, 2010 | 01:58 PM
moonsign's Avatar
I googled around and found a few real trick catch cans. Going to install one soon. Looks like installation is a "Bird nest on the ground', real simple. "Moon"
Old Jul 17, 2010 | 12:44 PM
Gas Man's Avatar
Moon, take notes and pics please.
Old Jul 18, 2010 | 12:29 AM
moonsign's Avatar
I ordered a red anodizes one, and then went under the hood to scope out a location. Man, there is'nt very much room to put much else in the engine compartment. Luckly, the catch can I bought[be here next week] as a samll one. Think I found a spot, just in front of the computer.
Will take pics. and notes, next week. "Moon"
Old Oct 19, 2010 | 07:56 PM
Timb727's Avatar
Was wondering... Just installed the superchips and boost is limited to about 20 psi. Took off the airbox cover the other morning to hear the whoosh and heard air leaking out around the 20 psi. I think it was from the wastegate. Will this spring correct this and will my boost go beyond 20?
Auto 2008 HHR SS Black
Old Oct 20, 2010 | 08:13 AM
JeramieJJ's Avatar
Basically it should just go between the valve cover and the turbo intake. Catches oil so you don't suck oil into the turbo through the intake.
installing catch cans is an age old thing. Cheapest way is to use a fuel filter, installed for proper flow. Get the clear, plastic one. Been on my '96 Eclipse GSX for years.....when it gets dirty or full, replace it. All snazzy, colored ones, won't let you see when it's collected crap.
This was a write-up done on the DSM engine (the turbo 2.0 long before us) catch can: http://www.tgilmore.com/talon/catchcan.html
Old Oct 23, 2010 | 08:45 AM
mistermike's Avatar
We LS1 guys have, unfortunately, accumulated a large body knowledge on oil sucking. Most nice fancy so called "catch cans" are unmitigated crap. They look pretty, cost a lot, and in terms of filtering oil out of air, rate about a "3". Generally, just a can stuffed with steel wool. For a very small amount of money, get a filter of the type used on air compressors. These are designed by people who actually understand fluid mechanics instead of some piston head who works in a machine shop. The little cheap ones sold at Home Depot work fine. They only thing you've got to consider is the polycarbonate bowl doesn't like to be pressed up against a hot exhaust manifold or cleaned with perchlorethylene. For a more extreme solution for high power engines, here's what I am using.
http://www.ls1gto.com/forums/showthread.php?t=320293
Old Oct 23, 2010 | 10:23 AM
asanti's Avatar
Jeg's sells one for $40 or $50. It worked fine on my all motor build. I'm thinking of buying another one but I'm not sure that the poly bowl holds up to boost though (?).
Old Oct 26, 2010 | 12:09 PM
Timb727's Avatar
I know this is off topic from the oil can but I wated to see if anyone else had the same results with the Dejon Spring. I ordered mine and installed it. The first thing I noticed was a strange noise when boosting. This was worse when the car was cold. (Almost like I had bad gas in the thing. No noticible gains in acceleration or boost. Decided to junk the spring and go back to the stocker. Runs perfect again. I do not recommend this spring for superchips users.
Old Oct 26, 2010 | 12:12 PM
Timb727's Avatar
Also, I took the spring out and reinstalled twice with the same results. Clamps are all tight and boost is at 20.
Old Oct 27, 2010 | 06:04 AM
mistermike's Avatar
If your manifold pressure is making it into your crankcase, you're in serious trouble.
