FE1 or FE5 steering rack?
FE1 is soft ride...FE5 is sport. I don't race, I don't need to race, I don't need to take turns at 40mph, etc
Will FE1 work for an SS?
Looking at these 2 on rock auto
I can't seem to figure out how to link a rock auto part, so I'll copy and paste
1:
CARDONE 1G1814 Remanufactured; Includes Inner Tie Rods Info
with Soft Ride Suspension (FE1); Electronic Power Steering with Manual Rack
$165.00 shipped
2:
CARDONE 1G1815 Remanufactured; Includes Inner Tie Rods Info
with Performance, Handling Suspension (FE5); Electronic Power Steering with Manual Rack (Only 1 Remaining)
$210.00 shipped
OR should I just go with a NEW GM OEM FE3 for ~$250?
Uncertain if the steering rack is easy to service myself, or if it's even possible?
1:
with Soft Ride Suspension (FE1); Electronic Power Steering with Manual Rack$165.00 shipped
2:
with Performance, Handling Suspension (FE5); Electronic Power Steering with Manual Rack (Only 1 Remaining)$210.00 shipped
besides the advantage of a higher ratio with the base model steering rack, is there any other advantages over the ss rack?
will it fit and work? Are there any other differences?
seems like you want a higher ratio on the bigger wheels to help turn them
Ok thanks for the info. I see on Rock auto that only the gm genuine have hearts next to them. I'm assuming this is one of the items I need to stick with OEM?
In the RA website I don’t see any genuine GM FE5 racks.
https://www.rockauto.com/en/catalog/...nd+pinion,7388
Here was the correct part number for the FE5 rack, sadly also discontinued
https://www.gmpartsgiant.com/parts/g...-25956914.html
