Front Control Arm Front Bushing Install
Old Jan 21, 2021 | 08:59 AM
LT1GMC's Avatar
Replaced all front suspension with original or Moog parts on my HHR SS. Purchased the Moog K200361 front LCA bushing. It looks smaller than the one in the control arm, plus how do you get the old one out and new on installed? Any thoughts? I did not change it since the original ones looked new, but still could if I was sure they were right before destroying the old ones getting them out.
Thanks!
Old Jan 21, 2021 | 10:04 AM
You've got to press the old out-new in with some type of press. Either a tool made for the job or some have "fashioned" their own press.
BUT. On the SS it makes more sense to replace the entire Lower control arms with the correct FE5 arms. That way you'll have new front and rear bushings and the correct FE5 ball joint . No sense in replacing the 1 bushing and still having the original, worn ball joint.
FYI. Rockauto carries the correct AC Delco LCA's for the SS. We have the part # in the Common Used Parts sticky.
Old Jan 21, 2021 | 10:52 AM
I’ve never had to change the front bushing in the LCA’s, just the rears
stidge77
Apr 10, 2019 01:34 PM
SwissHHR
Apr 14, 2018 07:02 AM
slonny
Dec 23, 2017 08:45 AM
alexrckid
11
Feb 26, 2012 07:46 PM
donbrew
0
Nov 5, 2011 02:01 PM
