Front Strut Mounts/Bearings
Folks, I need to replace my front struts and mounts on my SS FE5 suspension. Yes, I already read the parts listing HERE and I already searched this forum to try and find the answer. GMPartsDirect is giving me conflicting information. THIS PAGE lists a strut mount bearing (schematic #15, part #22712116). However, THIS PAGE does not mention a strut mount bearing. Can anybody clarify what is what? Typically the mount bearing is integral to the mount in most cars. Is that not the case for the HHR SS?
If you live and drive in a rust belt, get spring seat plates also part #8. PN 22716379
https://www.rockauto.com/en/catalog/...nsulator,10444
I just changed out struts and bearing plates and those are rusty enough to cause a creaky problem
I ordered the AC Delco ones from RockAuto, under $10.00 each.
https://www.gmpartsdirect.com/auto-p...uspension-scat
shows strut bearing as #15 and strut mount as #14, same as the other link
https://www.gmpartsdirect.com/auto-p...omponents-scat
#14,15 are the parts
both are in this AC Delco kit, Moog and KYB have similar parts available
These are the old in the left and new in the right strut bearings , or part#15 in the other link.
Those bearings are in the kit for the strut mount, sadly the spring seat isn’t, that’s the separate part I mention in my previous post
