For the guys who have changed their oil in the SS....
just making sure I read it right......manual calls for 5 qts for the 2.0, 2.2 and 2.4.....just double checking before I start, dont wanna put too much in and couldnt find exactly a 100% straight answer from the manual.....TIA
Easiest oil change ever. I get a 5-quart jug of Mobile-1 from W-Mart for around $23. And a filter from somewhere. You can pour the used oil back in the jug for recycling. Make sure you get a 1.25" short socket for the filter.
Granted, this is the 2.2, but it will be generally be the same.
https://www.chevyhhr.net/forums/show...ghlight=change
Oh, and that little white dot is an alignment thing. When you tighten it back up, just tighten it back to where it was from the factory.
When you're done, tell us how way-easy it was.
Here's the old filter coming out:
