Help / timing chain / fuel in crankcase ?
Old Mar 13, 2013 | 09:49 AM
pr455's Avatar
Hello HHR Forum,
Looking at a used 2010 HHR SS / auto trans. car with 40K miles, my concern at 36k the timing chain was replaced.
The GM dealership that made the repair service ticket states ( timing chain has excess play causing timing error – high pressure fuel pump leaking into crankcase )
The repair states ( replaced camshaft gear actuator, solenoid, timing chain, tensioner, high pressure fuel pump and pipe for fuel leak )
Questions:
How does fuel get into the crankcase, sorry don’t know much about the Ecotec engines.
Think fuel in the crankcase would have any long term problems?
Has anyone had any experience with this problem?
Any insight and or thoughts would be greatly appreciated.
thank you in advance for your time.
Pat
Old Mar 13, 2013 | 11:27 AM
solman98's Avatar
Timing chain replaced at 36K, now sitting on a used lot with 40K. I'd avoid like the plague.
Old Mar 13, 2013 | 12:08 PM
ChevyMgr's Avatar
High pressure fuel pump dumped fuel into crankcase. Very common. Timing chain not so common.
Old Mar 13, 2013 | 12:47 PM
prod's Avatar
I've seen 3 ecotecs with bad chain tensioners including mine, all 2007-2008 2.2 though. One was left too long and the tensioner shattered, bye bye engine. Sounds like yours was caught at the rattling stage.
the high pressure fuel pump runs off the timing chain, not sure if worn chain would cause fuel problems. At some point it could damage valves and pistons though, so I would be cautious.
Old Mar 14, 2013 | 07:22 AM
pr455's Avatar
Thanks
Thank you to all the replies to my post / question yesterday.
take care,
donbrew
Maintenance and Upkeep
14
Jan 13, 2016 12:53 PM
dooscoop32
Jul 15, 2015 04:59 PM
Banana hands
Apr 17, 2014 04:49 PM
lewie2792
Apr 21, 2013 03:16 AM
codered3232
22
Mar 6, 2012 09:01 AM
