HHR-SS -Service - Changing Oil Filter
Old May 14, 2009 | 10:01 AM
  #51
NY HHR's Avatar
My last change in April was - $26 for Mobil1 at Walmart, $8 for filter, took it to a dealer who services all cars and they charged $11 for the labor---total $45, the Chevy dealer here wanted $80.
Old May 18, 2009 | 10:31 PM
  #52
Paul's hhr ss's Avatar
oil changes
Oil changes are very simple on the SS. It takes the special socket or a 32mm socket from the top side and 5 quarts of Mobil 1 and 20 minutes to do the job. And thats by a 61 year old guy!
Old May 18, 2009 | 11:00 PM
  #53
c2vette's Avatar
Originally Posted by lteton2
Watch it when you go to the dealer for oil changes. They filled mine first time with fossil oil and I had to have them change it again. Luckily I thought to ask before I left the shop. If they would have looked at the cap, it say's Mobil 1 right on it. To their credit though it was a free change and their first on an SS. Always ask!
Same here. My first and only oil and filter change at the dealer had to be done twice (the service manager caught it though at check-out). It actually does matter more than you might think. The pistons in the turbo motor are cooled from the underside by oil jets, and under high load high boost can get hot enough to cause most conventional oils to leave deposits. Synthetic has very high temp capabilities and the pistons will stay clean.
Old May 20, 2009 | 08:02 PM
  #54
87silver's Avatar
Originally Posted by a76marine
I received the oil changes for life in my deal and took it back to the dealership for it's first oil change last week at 2,700 miles.
They ended up charging me $25 extra for the Mobil One, my gf drives a new Cobalt and got the same deal on oil changes and hers was absolutely free.
My question tho is if the dealership changes the oil in the turbo (have heard they do not) and if this is something I should be doing each oil change or what?
Hope you have better luck than me with "Lifetime" oil changes. I had the same deal with my CTS at Harriman Cadillac. They went out of business. But at least the ones that they did, they didn't charge me anything for, even though the CTS was also a Mobil 1 car.
Old May 29, 2009 | 09:42 AM
  #55
bigallis1's Avatar
Totally agree with you on this one Paul, and I'm 62.
Old May 29, 2009 | 03:00 PM
  #56
KinseySS's Avatar
It costs me 70 bucks to do a synthetic oil change at my dealership and that's in Canada. Cost wise its not really worth it to do it myself and this way I won't have to worry about possible warranty issues down the road. I was told it was relatively easy to get to the oil filter, but cant say since I haven't done it myself yet.
Old May 29, 2009 | 03:55 PM
  #57
XXL's Avatar
XXL
Lifetime of the dealer... sort of like our warranties... lifetime of GM. (tick tick tick)
Old May 30, 2009 | 02:51 PM
  #58
BZERKED's Avatar
With 35,000 miles behind me I havent had an issue with oil changes. I have used Mobil 1 and Q when the local parts place was out of Mobil. Q meets all the same spec's and ya save a $1 a quart. I have use the K&N($20) oil filter and the Bosch ($7) with zero issue. With the filter on the top side oil changes are a snap and run $50-$60
Old Jun 1, 2009 | 10:23 PM
  #59
BAD1200XL's Avatar
I just changed mine at 8Kmi, first time for me. SS had 6kmi on it when I got it. I switched to Amsoil 0W30 Signiture series with the Wix filter. I for sure notice better startups, mpg's. Have switched all vehicles. 05 GMC Sierra saw very nice improvments also especially the trans. Much nicer shifts I feel. Amsoil just released there new DEX VI replacement I plan on changing SS auto trans at 25k mi. to this new syn ATF.
https://www.amsoil.com/dealer/action...wsJune2009.pdf
Old May 30, 2010 | 01:50 PM
  #60
lady3bglover's Avatar
Originally Posted by Snoopy
Tom.....
I BELIEVE he is speaking of the K&N OIL FILTER.
I tried the K&N Oil Filter on my truck and I didn't see spending the money on it again. So I went with WIX with the anti-flow back on it.
But b/c I'm changing the oil on the HHR SS, I'm sticking to all Mobil 1 products.
If I can change the oil on my truck the SS shouldn't be that much of a trick.
This is what I needed to change the filter...
3/8 drive, 10" 3/8 extension, 3/8 to 1/2 swivel, and 1 1/4 shallow socket.
I tried using the standard 1 1/4 socket but it was too deep and limited the amount of room that I had to remove the filter. The shallow socket is made by Lisle (part#14700) and it's cost was about $12.
