How to change wastegate?
Canyone tell me if I can use this vacuum pump (for brake bleeding) to test the wastgate actuator?
Someone told me to use this....just hook the vacuum line up to the wastegate actuator, pump it up, and see how many PSI it opens up at...
Does this make sense to test the wastegate actuator?
