I need a clutch, any suggestions
Old Apr 10, 2010 | 04:28 PM
sick1's Avatar
Did a search but couldn't find an answer to my question. Put an HP tuner on my 08 SS a while back, with the extra power and with getting stuck in a ditch this winter, it appears I've all most ended the life of my clutch. It's slipping in 4-5 gear, and the emergency brake has to be set if I'm on any incline at all. Only have 20k on the odometer. Going to do the GM stage one and have it tuned again, and that will be it for the mods. Looking for a fairly streetable clutch that will last 100k+, I don't mind spending money, just want one that is going to handle the power, be streetable, durable and also where to buy it from. Any input would be appreciated. I will be ordering one early next week. Thanks guys.
Old Apr 10, 2010 | 06:58 PM
bartSS's Avatar
Exedy Hyper Single!!!
Old Apr 10, 2010 | 10:14 PM
sick1's Avatar
Do you happen to have a link on where one could purchase the Exedy??? I looked at some of the site vendors and don't see them listed any where. Thanks
Old Apr 11, 2010 | 09:17 AM
bartSS's Avatar
Go through TTR. They have the best price on it. And im pretty sure they're a vendor on here
I have the clutch in min and the thing grabs like cazy. Keep in mind i have full bolt-ons on m car with the stage kit and HPTuners
Old Apr 11, 2010 | 09:38 AM
TurboTechRacing's Avatar
Former Sponsor
Yup, if you have the "SS" HHR turbo, the exedcy clutch kit/flywheel is the ONLY way to go:
This is the one in which will fit:
http://www.turbotechracing.com/produ...12&idcategory=
You can go with less/cheaper, but you wont be happy in the long run. The ONLY other one we would state would be close is the SPEC Stage 2+ and 3+ setups...
Old Apr 11, 2010 | 10:22 AM
sick1's Avatar
Thank you Sir, just placed the order.
Old Apr 11, 2010 | 10:23 AM
bartSS's Avatar
Make sure you find a shop that knows what theyre doing bud
Old Apr 11, 2010 | 10:33 AM
sick1's Avatar
Around here may be tough to do (Columbus, Ohio), was thinking of having the dealership install it, but I need to check around some more.
Old Apr 11, 2010 | 12:24 PM
decepticonss's Avatar
How is this clutch for a daily driver?
Old Apr 11, 2010 | 01:16 PM
bartSS's Avatar
It took me about a week to get us to it. You have to give the car some gas before you release the clutch otherwise it will chatter. It is a racing clutch so it is a liittle stiff but the thing grabs like crazy. And guys make sure you beak it in properly. Do not slam gears until after 500 miles. Yes that means no NLS for a while lol
