Knock sensors P0332
Old Jan 17, 2023 | 07:57 AM
"Circuit Low" means voltage. Wire or connector, maybe fuse.
Your reader needs updating I would not trust anything it says.
Old Jan 17, 2023 | 01:55 PM
hhrumadbruh's Avatar
This was just with a $7 obd Bluetooth module and my tablet. Should I seek better diagnostics at a shop?
I've driven the car 500 miles so I assume any cleared codes would have popped back up by now?
Old Jan 17, 2023 | 03:41 PM
Originally Posted by hhrumadbruh
Apparently I have this code too
so this was a code you had, you cleared the code and it has not returned after 500 miles or so.
Old Jan 17, 2023 | 05:55 PM
PulpFriction's Avatar
As long are the cheapie dongle works, the reliability of the data will be driven by the app not the dongle. The apps typically offer updates periodically but not much about HHR should change at this point .
What app(s) do you use?
Old Jan 17, 2023 | 06:39 PM
codes were cleared before I bought it. I didn't see this until I got curious with the obd scanner apps. So the red means it hasn't popped back up but the orange means it's current?
Old Jan 17, 2023 | 06:40 PM
  #26
Thanks for the info. I'm using torque pro and scanmaster lite currently.
Old Jan 17, 2023 | 07:39 PM
  #27
The statement, no trouble codes are detected . That’s the important one.
Old Jan 17, 2023 | 07:47 PM
  #28
hmm so the stored code is active? (Check gas cap)
Old Jan 17, 2023 | 09:46 PM
  #29
Stored is the same as historical, you had that code in the past, it went away. Pending means it hasn't quite set yet, they can sometimes help diagnose some other code that has set.
Old Jan 18, 2023 | 06:19 AM
  #30
X2^^^^^^, thanks Donbrew for the explanation.
