Lack of power on acceleration
Old May 28, 2013 | 01:25 PM
penning4544's Avatar
Drove a long trip, a couple of hours, when I turned a corner to accelerate, the car wouldn't go, just felt like it was bogging down, thought I heard a backfire. I floored it, didn't seem to make any difference. Car was generating boost like normal. I let off the gas, and floored it again, car took off like normal. On the way back on my trip, car did the same thing twice. No warning lights or any boost issues according to the gauges that I can see. Any ideas? I don't have any tools to check codes.
Old May 28, 2013 | 03:27 PM
badassbowtie's Avatar
Hmmm. Check and see if your air filter didn't slide off when you went around the corner...
Old Jun 2, 2013 | 05:43 AM
bigjacksauto's Avatar
If you can Drive it OK go to local advance auto or better yet call first and see if they can check for an engine code.if your check engine light is on pretty much any scanner will pull and list it for ya if its running that bad and no check engine light then you will need a better scanner to find stored codes.
Any more info on this issue
Old Aug 16, 2018 | 12:35 PM
Roger Barto's Avatar
How could that stock air cleaner slide off? It's bigger than the engine!
Old Aug 16, 2018 | 02:03 PM
Just the rubber elbow can loosen up.
Old Aug 16, 2018 | 07:29 PM
This is about the SS, it's not that big.
This is about the SS, there is no elbow.
badassbowtie may have been messing around with that response. Who knows, but it's not going to slide off.
This thread is over 5 years old!!
Old Aug 17, 2018 | 10:36 AM
Yep, it’s about an SS. Over 5 years old.
BLUEHHRSS5SPEED
41
May 13, 2016 06:12 PM
danger
2.2L Performance Tech
Jan 11, 2011 10:10 PM
chudlychudson
Sep 14, 2009 05:21 AM
chooch
Jan 22, 2008 04:47 PM
chooch
Nov 26, 2007 09:54 PM
