Manual transmission 5 speed
Old Jul 8, 2021 | 05:17 PM
Caveman's Avatar
I’m in need of HELP finding parts for the 5speed manual transmission in my 2008 SS ...
i have been told that I have the T-35 Transmission in the car ...
need a good Reliable source for the parts ... any help will be appreciate it ...and THANK YOU ... in advance ..
Old Jul 8, 2021 | 06:21 PM
You're close, it's an F35. What parts?
Old Jul 9, 2021 | 06:56 AM
Welcome to the site! X2… internal parts ? Shifter cables? Clutch assembly? What parts do you need?
Old Jul 9, 2021 | 07:05 AM
Welcome
Since you don't say which parts you need, I can only point you to the correct HHR SS 5 speed. You can then search for your parts.
The HHR SS uses the Saab F35 transmission. The RPO code is MU3 for that trans.
MM5 Merchandised Trans - Auto Provisions, O/D
MN5 Transmission - Auto 4 SPD, HMD, 4T45-E
MU3 Transmission - Man 5 Spd, SAAB, 76.5 mm, 3.38 1st, 0.70 5th
MX0 Merchandised Trans - Auto Provisions, O/D
M86 Transmission - MAN 5 SPD, GETRAG, 5T45-E, M, F23, 75 mm, 3.58 1st, 2.02 2nd, 1.35 3rd, 0.98 4th, 0.69 5th
NE1 Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs, GVW (Use 2003 Mdl Yr)
Old Jul 9, 2021 | 08:45 PM
PulpFriction's Avatar
Are all SS 5-speeds LSD?
Old Jul 9, 2021 | 09:00 PM
No.
( The RPO code for LSD is G85 if you wanted to look at the glovebox sticker )
Old Jul 10, 2021 | 07:25 AM
These guys rebuild F35 transmissions , perhaps contact them for parts
WERKSracing F35 Stage Transmissions, Performance Autowerks
Old Jul 12, 2021 | 02:55 PM
Caveman's Avatar
Please enlighten me to what does the LSD stand for ...
and yes I do have the G85 code ...
Old Jul 12, 2021 | 03:02 PM
Lonwane's Avatar
Limited Slip Differential
Old Jul 12, 2021 | 03:03 PM
Limited Slip Differential ---- LSD
And again. What "parts" are you looking for ?
