Manual transmission 5 speed
I haven’t even pulled the transmission out let ....
I’m trying to locate a good source supply ... Before I pull it out and open it up ...
i have tried that site that ol Blue had mentioned ...
And they have rebuilt transmission for around $1,995...
I believe that is the way I’m going for now ..
But I want to Thank you for helping educate my old dumbass self...
my local transmission shop is saying around $5,000. + what ever else...
and I’m not going way ...sorry for any confusion I may have stirred up ...
No confusion. We were just asking what "parts" so we could give you opinions.
Sounds like you have internal failure and those shops have quoted for a total rebuild. If it's a budget issue, maybe check into locating a used MU3 transmission.
When GM came out with the 2.0 turbo line of cars (HHR SS, Cobalt SS, Pontiac Soltice, Sky) the GM performance division developed the turbo upgrade or "Stage One" kit as it was called.
The kit was just two, 3 bar Tmap sensors, wiring connectors and a computer reflash that had to be done at a GM dealer.(it was dealer only when the kit 1st came out. There may be some independents that now have those reflash files.)
It would increase the specs on the HHR SS to 290 hp, 315 torque. Stock was 260 hp, 260 torque.
Back in 2010 or so, the cost was about $700 for the kit and install.
Not even sure if this is even available thru GM anymore. Since the reflash had to come from GM and they shut down the GM performance division several years ago, not even sure if you could get it done by a dealer.
Thank you ...
Black on Ebony .. for that bit of information on ZZP Performance ...
i did check with them ...
And I found out that they did use to have them ...
But hadn’t had them for over a year ...
sense GM had discontinue them ...
And thank you for helping me ...I’m still in the hunt for what I can find out ...
