Motor knocking
Not OK to drive. Not OK to start. Every start risks ruining the engine until you know the timing chain is good.
What may be happening is less noise when the oil-actuated timing chain tensioner is already applying tension because of partial initial deployment due to recent operation.
Is the check engine light on? If so, for how long.
Find a reputable mechanic with confidence in doing Ecotec chain jobs and ask what they charge for your specific car before you take it there.
Do you have a scanner or have a friend with one? The car should be scanned for codes but not driven until you better understand what's wrong.
If the exhaust cam is out of time with the crankshaft then the problem will be the timing chain, the camshaft position sensor is working, telling you the camshaft is out of time!
Great now I have Hall and Oates sing rattling in my head!
I also finally managed to get a video of the knocking from the engine bay. New discovery- sound goes away entirely when clutch is pushed in.
Here’s the video; https://youtube.com/shorts/NOL6AJ-yuFg?feature=share
