Motor mounts for the ss auto?
Old Dec 5, 2018 | 10:46 AM
  #161
TurboTechRacing's Avatar
Former Sponsor
More in stock!
Old Jan 23, 2019 | 05:11 PM
  #162
Former Sponsor
More shipping out.
Old Jan 24, 2019 | 10:51 PM
  #163
Pretzel's Avatar
Mine arrived last week. Not installed yet.
thanks Aaron
Old Apr 16, 2019 | 04:40 PM
  #164
Former Sponsor
More shipping out.
Old Apr 19, 2019 | 02:44 AM
  #165
Pretzel's Avatar
Hello Aron,
i have a problem with your Auto engine mount.
The forward bolt hole is too close to the bend to use the stock nut. The stock nut is a combo nut/washer and it would not fit.
When I first put the nut on and it started to go but after 2 threads it popped off because it hit the side. Took me an hour to fix the threads.
i didn’t want to drill out the mount til I heard from you. The aft hole is drilled in the middle of the mound. The forward hole is drilled to the side more so.
see my attached pic for details.
Old Apr 19, 2019 | 07:00 AM
  #166
Former Sponsor
Originally Posted by Pretzel
Hello Aron,
Replied to your email, never have we this before, ever... Only thing I can conclude is if you are not the original owner, someone installed a larger diameter nut/washer than normal on your HHR at one point.
Fix is to sand the washer down a little, as it will not take much.
Old Apr 19, 2019 | 07:21 AM
  #167
Mine was a tight fit also on my 5 speed. Just do as Aaron said and file down the washer a little bit. That's what I did.
Do Not try and redrill the hole in the mount. That would cause the mount to sit a little ****eyed from where it's supposed to.
Old Apr 19, 2019 | 08:40 AM
  #168
Former Sponsor
Correct, do not drill, hole must be there to be aligned straight/perpendicular to the engine. Bases on these mounts are both the exact same, it is the upper engine support component that is different between auto and manual trans.
It obviously is a faction of interference being the nut started a couple threads. we know it is close, as it must be, as it transfers the structural load thru this point.
file/sand the washer a bit, or get a smaller washer for $.25 and a new nut (it is metric) .
First make sure you are not connecting the mount to the engine, and not installing the other base nut tight. Get this nut on and tight first, before you install any other fasteners. Pull the TTR mount base to allow max clearance in that area also, as there is a little play in the hole to stud size.
Old Apr 19, 2019 | 04:34 PM
  #169
Pretzel's Avatar
Aron: I grinned the nut/washer a bit and all is OK.
@firemangeorge I seen in your picture that your forward nut washer was a bit smaller so thank you very much for the reply.
Cheers!
Old Apr 19, 2019 | 05:47 PM
  #170
Former Sponsor
Sounds great, thanks for the update.
