Need help I can’t figure this out
Old Dec 13, 2025 | 03:15 PM
  #31
Yes they could it doesn’t take much of a nick to allow 2200 psi of fuel to squirt by. If there is a nicked oring, you’ll have to replace those. If they are older they can dry out and shrink , this also allows fuel to leak by!
as for the fuel filter kit, open that page up and read the article, very informative. And I couldn’t find parts to make that kit for less money. It’s all part of keep it clean and drive it often
and spark plugs , AC Delco 41-108 Iridium? I don’t recommend touching the gap, but you can clean them with throttle body spray cleaner or brake parts cleaner spray.
Old Dec 13, 2025 | 03:17 PM
  #32
Quit driving the car or even running the engine. If there is that much fuel in the oil then the oil has thinned out and lost its lubrication qualities.
If you keep driving it, you’re risking engine or turbo failure.
this post, yes please take FMG’s advice! You don’t want broken rings or ring lands on those pistons .
  #33
Scooby9160's Avatar
everything on the injectors is brand new, including O-rings, but that doesn’t mean that there can’t be something stuck inside of it, but I do have a very good flow rate on the injectors
Old Dec 13, 2025 | 03:19 PM
  #34
I was referring to the 1st post that said you had driven it 200 miles.
That’s why I said Don’t drive it.
In fact, I wouldn’t even start it until you change out that diluted, overfilled crankcase.
Old Dec 13, 2025 | 03:21 PM
  #35
Scooby9160's Avatar
I gave done three oil changes on this car since I’ve had this problem and I’ve only driven it like 200 miles since, the oil that’s in there now has like 2 miles on it
Old Dec 13, 2025 | 04:35 PM
  #36
So, the logic is since the intercooler and related piping was installed just before this started there is no chance the cause could be related?
Old Dec 13, 2025 | 05:03 PM
  #37
Scooby9160's Avatar
im asking how this could cause fuel to be in the oil?
Old Dec 13, 2025 | 06:13 PM
  #38
The SS has a procedure for changing fuel injectors, more complex than the NA engines. Part of it is reaming the ports prior to installation. There are more steps, of course, I don't remember what else. It's probably in the free manuals that are linked to in donbrew's signature.
If you didn't know about the procedure, then that may be the reason for the possibility of damaging the seals.
Old Dec 13, 2025 | 10:41 PM
  #39
The code you cited implies the fuel TRIM is rich. The trim richens in an attempt to make the A?F 14:1. If there is a big unmetered air leak it would cause the computer to dump fuel into the mixture, Excess fuel in the combustion chamber would flood the chamber and fuel would go past the rings into the crankcase.
The only way fuel can get into the crankcase is getting past the rings. That takes excess fuel in the chambers.
Old Dec 13, 2025 | 11:27 PM
  #40
Scooby9160's Avatar
so why you are saying is I could have a vacuum leak or a intercooler leak that is making the car dump to much fuel to try and compensate
