Need help, Please!
Old Feb 4, 2016 | 01:32 PM
The last time I had a "biased rich" O2 code it was indeed a bad O2 sensor. The wires had chafed on the frame.
A stuck rich O2 sensor will cause the engine to run lean. The ECU sees "rich" and cuts back on the fuel in an attempt to get the A/F ratio where it's supposed to be. Also causing the misses.
Old Feb 4, 2016 | 01:35 PM
Doctor Who's Avatar
Originally Posted by DrLoch
Speaking of battery, how old is it? Disconnect and wait then reconnect. My guess is that you are having issues with the #1 O2 Sensor. If it's reading lean it will be throwing a lot of fuel at it hence the black smoke coming out of the exhaust.
Yes I'm north of Mebane, actually north of 49 up 119.
Battery is about about 6 months old.
Which is the number one? Where is it located? I found the one nearly in the middle of the car after the converter. I guess that is #2?
Old Feb 4, 2016 | 02:05 PM
#1 O2 sensor is near the Exhaust manifold, #2 O2 sensor is after the first cat (if yours has 2).
Old Feb 4, 2016 | 02:33 PM
DrLoch's Avatar
Item 608 is the #1 Sensor. You can see it by looking down over the left hand (Driver Side) rear section of the motor
Old Feb 4, 2016 | 02:34 PM
Doctor Who's Avatar
I found O2 sensor 1. It is hard to reach but I have found it. I am going to clear the code and see what happens. That is exactly what I needed to find it. Thanks for that diagram.
Old Feb 4, 2016 | 04:52 PM
  #26
Doctor Who's Avatar
I cleared the code and hasn't come back yet but I have not driven it yet. Will do that in the morning.
Old Feb 5, 2016 | 12:35 PM
  #27
Doctor Who's Avatar
CEL came back on and it is still not running right. Have we decided that it is the O2 sensor number 1 that may be causing it?
Should I take it to the dealer for service?
Old Feb 5, 2016 | 12:51 PM
  #28
What is the current code?
Old Feb 5, 2016 | 01:14 PM
  #29
Doctor Who's Avatar
I will check it when I go somewhere either this evening or in the morning.
Old Feb 6, 2016 | 10:33 AM
  #30
Doctor Who's Avatar
I got it scanned this morning and got code P2196. That says P2196 O2 Sensor Signal Biased/Stuck Rich (Bank 2 Sensor 1) Code
Read more at: http://www.obd-codes.com/p2196
So what do I need to do? Replace the O2 sensors?
