No crank
Old Feb 23, 2024 | 01:19 PM
Originally Posted by Alcutcha
Thank you again, I will keep all of you updated, RockAuto here I go.
so far we haven’t recommended any parts to be replaced.
Old Feb 23, 2024 | 01:42 PM
Alcutcha's Avatar
I thank you again, and I understand no recommendations, Sincerely Al
Old Feb 23, 2024 | 02:02 PM
Find yourself a good mechanic. If you don’t know what a coil is or the difference between a fuse and a relay, then you shouldn’t try any repairs yourself.
Old Feb 23, 2024 | 02:10 PM
That’s why we are here FMG for advice on how to diagnose a problem and get it fixed either by a mechanic or yourself and ensure somebody doesn’t take advantage of you.
Old Feb 23, 2024 | 03:00 PM
Alcutcha's Avatar
Thank you again FMG
Old Feb 23, 2024 | 05:32 PM
You can remove the coil, ensure it’s clean and dry.
Old Feb 24, 2024 | 07:38 AM
I think the pictures are not in the correct order, The coils are not in the position described; #3 is closest
Old Feb 24, 2024 | 09:27 AM
Photo #1 ….. a coil
Old Feb 24, 2024 | 09:56 AM
Yes, on the SS, the #4 coil is between the air box and the fuse block.
Old Feb 24, 2024 | 10:00 AM
Alcutcha's Avatar
would one bad coil shut down all electricity to the engine, good morning and thank you
