Oil Problem?? maybe, maybe not
Old Apr 5, 2012 | 08:23 AM
foolmoon_design's Avatar
Hopefully ChvMgr can answer this,
during a recent oil change, I checked the dipstick before draining the old oil, and it was mostly dry for thre or four plunges. I was a little worried, until draining the oil and making sure I still had 5qts. more or less. would the slight angle of my drivway have caused that off of a dip-stick reading, or something blocked?
Old Apr 5, 2012 | 09:37 AM
solman98's Avatar
It's always best to check on a level surface and after the motor hasn't been running for 30 minutes or so. Otherwise you won't get an accurate reading on the dip stick.
Old Apr 5, 2012 | 10:46 AM
level surface warmed up oil works much better, I had the same thoughts of terror 1st time I checked mine cold on the driveway nose up 3 inches higher
Old Apr 5, 2012 | 03:30 PM
badassbowtie's Avatar
i always poor the old oil back into the jug, just to make sure i get every ounce of 5 quarts i put in.
Old Apr 5, 2012 | 06:46 PM
Thats what I did, made me feel alot better, I thought I might have been a quart or so low. Not the case, just angled driveway.
Old Apr 5, 2012 | 07:57 PM
ChevyMgr's Avatar
As was said already; level parking and at least 10 minutes should be okay but longer is preferred.
Old Apr 6, 2012 | 07:32 AM
Thanks MGR! I usually wait half hour or longer. I know the quick change places do it quickly, I just don't like exposing hot parts to cold oil, so I do it myself. We just moved to a new house, and I guess the driveway thrwe me off.
Old Apr 6, 2012 | 07:36 AM
AC66Bronco's Avatar
you wont get EVERY oz you put in back or else the oil is not doing its job.
/ nit-picking.
urbexHHR
Nov 3, 2010 07:00 AM
06gray2ltHHR
2.4L Performance Tech
Aug 1, 2009 10:45 PM
ts5p
Oct 6, 2008 02:47 PM
suburbanjunior
Apr 1, 2008 01:12 PM
Black Rose
Dec 7, 2007 11:28 AM
