One second grind on cold start.
Old Mar 21, 2012 | 04:58 PM
Tyler Harvey's Avatar
Hello everyone. I'm looking for some help in this. When I start my HHR, after two seconds of running it makes a one second "flutter/grind" sound. This only happens when it's been sitting for at least a couple hours. It sounds worse when sitting over night. I'm going to try and pin point the area. My car isn't hesitating, idling rough or bogging at stop lights. I just have this weird one second sound that I don't like! Any help would be greatly appreciated.
Thanks
Old Mar 22, 2012 | 09:37 AM
rroadkilll's Avatar
I'm noticing the same thing in the morning...
Old Mar 22, 2012 | 09:40 AM
prod's Avatar
Starter solonoid not disengaging?
Old Mar 22, 2012 | 11:28 AM
Thanks
Tyler Harvey,
I'm sorry you are having this issue. Have you considered having this issue addressed at the dealer?
Evan, Chevrolet Customer Service
Old Mar 22, 2012 | 12:53 PM
us11csalyer's Avatar
Have you started using a different oil and filter? Sounds like it could be your throw out bearing.
Old Mar 22, 2012 | 01:02 PM
pitbull76's Avatar
He has an auto so no throw out bearing.
I do notice something that might be what the OP described when I start the car... I think it is the auxiliary brake vacuum pump cycling on so it has proper vacuum for the brakes. I wouldn't call it a grind, but I do notice a noise and a short-duration drop in the idle right after starting the car. It's done it for a long time.
Old Mar 22, 2012 | 01:15 PM
Didn't know the SS came with auto as an option.
Old Mar 22, 2012 | 01:28 PM
Did you think, only edges have auto ??
ChevyMgr's Avatar
Could be your ABS module doing it's self check at start-up.
Old Mar 22, 2012 | 01:32 PM
That was very productive...
