One second grind on cold start.
No, I'm not using different oil. Only Mobil 1 since day one. ChevyMgr, I have made an appointment for Monday morning.
I'm thinking brake pump or pulley related. Prod, I thought the same thing at first being starter related, but she turns over very easily. Yes, Pitbull76 I'm getting a slight drop in idle as well for that one second. Can't be the timing chain, my car only has 19k. I will let you guys know the outcome and thank you for your help so far.
Hello again. So, I've decided to hold off on my appointment until I can pin point the issue. She started fine yesterday (weird). When I talked to the dearlership they figured it could be the timing chain (can't be). Searching the internet on this seems to be very unclear as to what it would actually be. Nobody seems to know. I'd rather head in to the dealership with a answer. I don't want them taking the whole engine apart and not have a solution.
I will keep my eye on it and may be posting on this thread again. Regardless guys, I will post the outcome. Thanks.
Mine does this Everytime upon cold start up. I had a 2009 SS auto before the 2010 SS 5speed I have now and they both did this. The 2009 never had a brake vaccum installed so don't think that's Wut it is. Im sure its nothing to b worried about.
Hmm, im wondering now if you might be describing the old "piston slap" noise, common on many gm engines. Mine does it too.
If so, I doubt you will fix it short of an internal engine rebuild.
As my quest continues to determine the cause of this issue. When I leave my heater setting on full blast and then start the car, it makes the noise. When I have the heater off and start the car, you can hardly hear it. It's been cooler here the past couple of days. I'm thinking ac compressor or fan related now. Any ideas?
Thanks HHR SS QC, I'm now thinking the same thing, being the second owner, I gonna find out through the dealership to see if the recall was done on mine. Funny thing is, I never had the issue of having to press hard on the brake since I got, mind you I always let it warm up for a least a minute on cold starts. Letting the boost settle is always a good thing.
That's a good way to confuse someone.
