Overboosting way past normal.
Old Dec 12, 2010 | 10:17 PM
Spozo's Avatar
Originally Posted by turbotech
My gauge will touch 28-30 most of the time i hit WOT. Had a code for this once. I turned the code off. No more worries. I've been running with this setup for over a year nad have had no issues. With a TECH 2 the boost PSI will actually read 40lb before I close throttle. Then it spikes to 44lb
I'd be looking for a way to turn the code off.
When using the Tech2 subtract 14psi(ish) for barometric pressure.
HTH
Old Dec 13, 2010 | 01:55 PM
Gas Man's Avatar
That reminds me. So the tech 2 displays what type of PSI? The gauge displays a different type of PSI. Correct?
PSIA or PSIG boost correct?
Old Dec 13, 2010 | 06:57 PM
Spozo's Avatar
For BOOST on this model the Tech2 shows PSIa. The gauge, PSIg.
Old Dec 14, 2010 | 09:53 PM
c2vette's Avatar
I seem to have a similar issue. At 55,000+ trouble free miles, it is acting like the waste gate is stuck. It will boost to over 23 psi even at part throttle, and if I leave it at high boost for more than about 3 seconds it will go into a "limp mode" until the engine is turned off or the cel is cleared.
I removed the tune back to stock (which should yield about 15 psi) and it boosts to exactly the same level (23 psi plus). Going to take a look at the linkage, etc this weekend, and also check the MAP sensor (although wouldn't that affect the readout too?). Sure has snappy throttle response though!
Old Dec 15, 2010 | 11:54 AM
Gas Man's Avatar
Cool... good to know. TNX!
Old Jan 15, 2011 | 03:10 PM
c2vette's Avatar
Follow up to my post above. I replaced the Wastegate Actuator (it is a small solenoid with three ports on it for vacuum and pressure). Pain to get the hoses off because of tight access. The new one fixed my problem of overboost (24 psi at anything over about 1/2 throttle) and stopped the error codes since it is now operating properly.
This Actuator can fail in other ways that cause "underboost", but in my case it was the opposite problem.
Old Jan 16, 2011 | 11:29 PM
camaro98z28's Avatar
What did it cost
Old Jan 17, 2011 | 07:51 PM
c2vette's Avatar
Originally Posted by camaro98z28
What did it cost
I paid full retail at about $150.00. It could have been warranty but I did not want to hassle with leaving it at the dealer and a possible question about engine mods affecting warranty.
And by the way, it now runs so super smooth and crisp (about 22 psi max boost with Hahn/PPC Tune) that I am wondering if it may have partially failed earlier and that somehow affected part throttle operation too.
Old Jan 19, 2011 | 03:33 PM
Not bad and yes avoid the dealer with mods on the car. I think im still the only one to blow an engine but I 100% blame the HP tune that was put on my car. Funny thing is, I have not noticed any difference between the parts on and the stock parts running close to the same boost levels. I even took on the Z28 with no problem. :)
shortonmoney2
Feb 6, 2012 08:53 AM
masterchief1112
Jan 26, 2009 06:05 PM
LTSport08
Dec 9, 2008 11:02 PM
Applenut
Aug 22, 2007 01:16 PM
SIHHR
Nov 9, 2005 03:09 PM
