Overheating ?
Old Oct 16, 2010 | 03:41 AM
  #61
LawDog88's Avatar
Glad I didn't pick up that 09 HHR SS I had my eye on @ the dealership then..
Old Oct 16, 2010 | 09:30 AM
  #62
CNYMike's Avatar
Sorry to hear that; I hope you reconsider.
Old Nov 8, 2010 | 08:09 AM
  #63
wraunch's Avatar
Ok so it was 38 degrees here in NC when I left for work in my 09 SS that has 36k on it. I stopped at a light on the way in and noticed the temp was up to approx. 215 with the heat on. So I turned the heat off against my better judgement and low and behold it came down to 208. After a little stop and go it got up to about 217. Should I be concerned? Also, I always thought cutting the heat on helped drop the temp, why did the opposite happen?
Old Nov 8, 2010 | 10:13 AM
  #64
Zagohhr's Avatar
Totally Normal. Mine have reached once 115°C (about 239°F), going uphill, at 10 mph, with heavy traffic, with 41°C temp (107°F)... and just that time, never again.
Old Nov 8, 2010 | 11:58 AM
  #65
CNYMike's Avatar
If you're really worried about it, you can take it to your dealer and have them give it a thurough going over, but if they don't find any leaks, there's not much else to do.
BTW, my car continues to behave itself. Did I run into some anomalies caused by the first hot summer in years? I'll know next summer.
Old Nov 8, 2010 | 01:29 PM
  #66
wraunch's Avatar
Good deal. I'm going to get a bottle of coolant on the way home and check it tonight after it cools down to make sure I'm not a little low.
Old Nov 9, 2010 | 08:52 AM
  #67
wraunch's Avatar
Ok, so I checked it last night when I got home and I could barely see any coolant in the recovery tank. I added about a 1/2 a gal to it and that has filled it up to the cold fill line. Checked it again this morning and it is still full. I took it to the dealer and dropped it off to see where I might be losing the coolant. I have a small oil leak that I found 2 weeks ago that I needed to get checked out anyway so two birds, one stone I hope.
When I drove it in today the temps were much better. Stayed around 205, until I hit some bumper to bumper and it ran up to 214. Fingers crossed.
Old Nov 12, 2010 | 07:58 AM
  #68
wraunch's Avatar
So I took it to the dealer and the did a coolant system check and determined there were no leaks. So yesterday I parked it on a hill and when I came back out I noticed a large amount of coolant under the front drivers side. So I pulled the car to a flat spot and took my flashlight out and moved a few hoses around until, low and behold the 2 piece lower radiator hose had a hole that had worn in the side of the hose where it was rubbing against metal. Thanks for nothing dealer!!!
Old Nov 12, 2010 | 10:45 AM
  #69
that sux..
after repair, It you can't get hose away from rubbing spot, I would wrap that area of new hose with old rad hose to protect from future rubbing thru.
Old Dec 7, 2010 | 01:28 PM
  #70
jonboyb's Avatar
SS Running Temperatures
Never really watched the DIC digital temp gauge but the other day sitting at a redlight I heard the fan running and flipped it over to see 221 degrees (20 degrees outside) Since then I have watched it closely and see a range of 189 to 221.....yet the needle gauge on the dash never moves. Tends to run between 202-207 most of the time. Just concerned at why the needle never moves vs. the digital output (and I mean the needle literally does not move AT ALL once up to temp). Makes me wonder if I have a sending unit bad and also a thermostat with temp swings like that.
Anyone else watched the digital gauge and what range do you see. My SS has 50k on it now.
