Rear sway bar only?
Old Dec 13, 2010 | 11:46 AM
coreycooper's Avatar
Rear sway bar only?
After reading a few posts it dosent seem like any body has done the front sway bar? is there a reason for this? Has any body had rear only and both i would like the input .
thanks ,
Coop
Old Dec 13, 2010 | 12:07 PM
Doctor Who's Avatar
You can do both but as far as I have read all HHR's already have a front sway bar but do not have a rear one. So it is just a good idea to get more cornering performance to put a rear on on the car since it doesn't have one.
Old Dec 13, 2010 | 01:24 PM
bartSS's Avatar
I only have a rear on but i had coilovers on as well now i took the coilovers off and just have lowering springs on and i feel that the car handles like **** compared to what it was on the coils
Old Dec 13, 2010 | 02:31 PM
Mrs. DLVRNIT's Avatar
Well we've done the suspension upgrades from SS Shocks and Struts, Eibach Pro Springs, Progressive Tech Rear Bar, then to an Ott Performance Hardcore Rear Bar and then a Eibach Front Sway Bar! With the addition of each upgrade our HHR's handling was noticeably improved! So to those that say you do not need to change your Front Sway Bar, it is not nescessary but the upgrade of the front bar does make a noticeble difference in increased tracking! We would also note that with non-SS HHR's it is probably not recommended to upgrade the bars only without adding some type of lowering or levelling springs because of the HHR's "Top Heavy" nature!
Best-O-Luck ,
Old Dec 13, 2010 | 05:04 PM
TurboTechRacing's Avatar
Former Sponsor
Front is a pain to change, takes 1-2 hours, that is most likely why.
Old Dec 13, 2010 | 05:10 PM
Jeda13's Avatar
I have the rear. Nice and tight now. Not so waggy as before.
Jim
Old Dec 13, 2010 | 05:19 PM
We just couldn't imagine someone doing one without the other as there is a noticeable difference in the front end response! We also agree that the rear installs in less than 1/2 hour while the front takes a good 2 hours to install. Also we would recommend the front bar be installed while on a lift! Couldn't imagine doing the front bar swap on ramps or jack stands .....
Best-O-Luck ,
Old Dec 13, 2010 | 06:57 PM
Doctuh's Avatar
Do what matters
One can go crazy with modifications. I tried to limit to what I felt essential, and the only obvious suspension one is the rear sway bar because it's just plain ABSENT otherwise. I noticed improvement, and will see whether girlfriend sees enough difference to get a TTR for her soon-to-arrive HHR (if TTR still has one left by then). Lowering "leveling" springs, front sway bar, etc are at the "point of diminishing returns" from my perspective. Some things like stiffer mounts, though, make a meaningful difference only in the SS. I have a 2LT, so your experience may be different.
I also sometimes have to go up a steep driveway. I now have a trailer hitch and hitch-based bicycle carrier sticking out behind me. Lowering would be crazy for me!
Old Dec 13, 2010 | 07:51 PM
waiting on the pony express to get mine here must be stuck in the snow, I thought horses were hard to high center!!
Old Dec 13, 2010 | 11:48 PM
ALL HHR's have rear Torsion bars (stock) they are just a little anemic, if you want more fun..
I first added the SS/TC rear springs , great improvement due to lowering the C/G.. Then later I added the TTR bar, & more improvement yet.
It's all good..
