Rear sway bar only?
Old Dec 14, 2010 | 06:56 AM
coreycooper's Avatar
Originally Posted by Mrs. DLVRNIT
Well we've done the suspension upgrades from SS Shocks and Struts, Eibach Pro Springs, Progressive Tech Rear Bar, then to an Ott Performance Hardcore Rear Bar and then a Eibach Front Sway Bar! With the addition of each upgrade our HHR's handling was noticeably improved! So to those that say you do not need to change your Front Sway Bar, it is not nescessary but the upgrade of the front bar does make a noticeble difference in increased tracking! We would also note that with non-SS HHR's it is probably not recommended to upgrade the bars only without adding some type of lowering or levelling springs because of the HHR's "Top Heavy" nature!
Best-O-Luck ,
thanks Mrs.D for actually answering my question
CBurge33
Dec 1, 2016 05:14 PM
TiggersHHR
Mar 11, 2011 10:35 AM
Cat Man HHR
26
Aug 23, 2010 06:46 PM
