Replaced Starter, HHR SS Still Won't Start
Replaced Starter, HHR SS Still Won't Start - UPDATE: Moved to Repairs Forum
Hello everyone,
I've run into an issue with my HHR; it will not start. I generally don't post a lot on the forums because I can usually find any answers to questions in previous threads...lots of good information and helpful people on this site! That being said, there are still a few things that I need to troubleshoot, yet, but, I wanted to start a thread that I'll update as I'm working on the car...because any help and support will be appreciated.
Anyway, here's where I'm at:
So yeah, that's where I'm at now. I've looked at some older threads that dealt with very similar issues and they've proven to be very insightful in helping determine a plan of action. But, like I said, I'm still going to update this thread as I go about trying to fix my SS in case folks are able to provide any help. If you have any suggestions or questions I will gladly accept any advice!
I'll be looking at the car again tonight (8/13) and will update late tonight or tomorrow. Thanks, everyone.
- 2008 HHR SS, manual transmission, 52k miles, currently stock, all maintenance is up to date
- Last week the starter was just clicking and wouldn't work; instead of checking things out first I just went and got a new starter and replaced the old one. I realize I should've checked a few things out first, but oh well. The car will still not start.
- Here's what I plan to do next:
- I'll be rechecking that I installed the starter correctly and that it's actually good
- Checking relevant fuses and relays; I'm not as competent with electrical issues, so I'm afraid of missing something
- Doing a load test on the battery, my car battery charger is telling me that my battery is okay, but I'm still going to take it out and get it tested
- The test light will come out and I'll make sure that the starter is actually getting the charge it needs
- The cables that connect to the starter didn't really look corroded at all so I don't know that its due to a bad connection
Last edited by SuperSam; Aug 13, 2018 at 10:48 AM. Reason: I posted my thread in the wrong forum...
I'll add that to the list and specifically check it. Will update on what I find tonight or tomorrow.
If it is clicking but not turning it is not getting enough power.
Should be more than 12V at the alternator, starter, fuse box at all times. And solenoid when triggered.
Could be the flywheel has ground teeth, try turning the engine manually a bit.
