SS ball joint famine
Old Aug 27, 2021 | 04:48 PM
  #41
You did see them, but I advised to not advertise them as problem solvers as they did not actually have the problem solver bushings.
Old Aug 27, 2021 | 05:04 PM
  #42
AhhhhhA!! That's what it was! Hmmm... Still doesn't disprove that I'm losing my mind...
Old Aug 27, 2021 | 06:06 PM
  #43
It’s still in your brain inside your skull, at least that is what Sweetie tells me!
Old Sep 2, 2021 | 04:55 AM
  #44
PulpFriction's Avatar
I would prefer the ball joint separately. The control arms have the lower quality rear bushing, I'd rather get the Moog rear bushing. Or Moog control arms with problem solver bushing, then swap the ball joint.
Removal of the riveted ball joint looks like only a minor pain, but now I worry that boltIng on the new one in a way that it will stay put is less certain than rivets. Maybe that’s why GM never made the SS ball joint available loose.
Old Sep 2, 2021 | 06:36 AM
  #45
The bolts that Moog provided are pretty close in relation to the holes the rivets were in, you torque them to just 50 ft lbs , so more of a shear pressure then stretch
Old Sep 2, 2021 | 01:24 PM
  #46
lazaino's Avatar
If you're really worried, clean the mating surfaces with a clean solvent and use a bit of epoxy to keep them from ever moving, jut remember you'll need a bit of heat when you want to take it apart.
Ira
Old Aug 10, 2022 | 01:16 PM
  #47
Good ideas. Thanks!
(20.1 - 19.96) / 25.4 / 2 = 0.0106
I'm taking those shank diameters on faith. Anyone ever measured both?
My math is correct. Think it will work, though?
That’s from comment #4.
My math is correct but my typing, not so much. Should be 20.5 not 20.1.
(20.5 - 19.96) / 25.4 / 2 = 0.0106
Old Aug 10, 2022 | 04:41 PM
  #48
Measured in post #10 and #12
Old Aug 10, 2022 | 06:16 PM
  #49
Originally Posted by fastsuv
I asked Jimmy at CTR where we can purchase them once they are available.
Their answer was to ask how many I would need initially.
I am going to ask for 6 pieces to see where and how much they would cost.
Steve
let me guess. You asked for six pieces and never heard from Jimmy Ji again?
Old Aug 10, 2022 | 06:23 PM
  #50
Hard to imagine that was a year ago.
