SS Lower ball joint replacement
The Moog K80567 is listed as fits the FE5 and the FE3 Suspension hmmm , wrong!
I’m almost ready to order one to measure it and confirm the stud diameter
https://www.carid.com/moog/front-low...pn-k80567.html
He is probably on to us and trying to avoid the topic, LOL.
My ball joint for my FE1 part number Moog K80567, the pin or stud is 20 mm
I have a set of LCA’s I’m rebuilding for BeachBum1, I need him to confirm his suspension
FE1 or FE3? His LCA’s have 20 mm ball joint studs also.
Now Engine Crate says these only fit the SS FE5
Cobalt FE5 Lower Control Arm Rh 2008 - 2010 25930724
Cobalt FE5 Lower Control Arm Lh 2008 - 2010 25930725
So, I think if you want better handling get these and since the rear bushing is a weak point press them out and install K200792 or the K201285 zinc coated ball bushings
I’ve again received no input or answers from Moog or any other parts manufacturer
I do caution any SS owners to realize the effort we have made to come to this conclusion, and don’t order any ball joints for their SS as it will not be a cheap repair!
Well thats a bonus.
A side note to my LCA replacement saga. So with the proper LCAs installed my car was in dire need of a wheel alignment as one tire was toed in enough that the tire had a slight squeal every once in a while. The shop confirmed this and got me all fixed up, the car feels really tight now. But as a additional surprise, I'd say my intermediate steering shaft rattle has been reduced by a lot, almost none existent. About the only time I get that rattle under the steering wheel now is when going over really rough bumps like railroad tracks and such. I suspect that the wrong LCAs where working all the suspension and carrying thru the steering enough to rattle everything under the car.
It was a pleasant surprise, to say the least.
In my case, my Chevrolet dealer was the only place that could get them, and said they came out of Chevrolet USA. The part numbers below are what where ordered. The big list of parts on this website is correct, and only complete LCAs are what are available if you need to replace the ball joint on a SS.
25930724
25930725
(These link to Crate Engine Depot, but the part numbers are the correct ones)
25930724
25930725
So this thread makes my head hurt. I got all new bushings for my control arms but do they make a ball joint for the SS yet? I don't want to buy a complete control arm just for the ball joint and I don't want to pull it all apart until I have the correct parts...
