I would put shrink wrap over all of that. shrink wrap each one separately and then maybe one large over all of them.
This is some good stuff, it's self fusing silicone tape.
Gives you moisture, thermal and chemical resistance Manufacturer: RadioShack Mfg Part#: 640-2336 |
The tech that did mine installed new pins on the wires and installed them in the new connectors that plug onto the new sensors. NO BUTT CONNECTORS, NO EXTRA CONNECTIONS AT ALL.
Wish I could get my dealer to do this
Mine is in the shop again for turbo and performance related issues and they are replacing the T-MAP sensor again but I believe the ultimate issue is the electrical connections and soldering them would be an additional fix to the entire problem.
Do most Stg 1 kits need to be redone after the dealer does it? About to pull the trigger on one of these..
Originally Posted by Chief
(Post 559979)
I just wish more dealers were open to it. I keep asking mine to do a soldering job on mine based on the information I have found here and some GM Service Bulletins related to wiring issues causing the symptoms my car is having and they called me a car hypochondriac and said that me looking up service information on the internet for my car is like people looking for medical advice on WebMD or something. Needless to say I was a bit insulted and actually reported it to the service manager and the dealer owner. That is how I got the little data recorder that told them there was a problem. The only bad thing now is my car has been at the dealer more this month for repair then I have had it. I think if they would just take a little time and solder the wires along with anything else they fine it is a small favor to ask for all my inconvenience. |
Originally Posted by acpantera
(Post 558112)
(Post 558112)
http://www.autosoftsys.com/supra/ecuext/pinwire.jpg |
(Post 559979)
(Post 559979)
It comes down to the tech who does it and how well he is trained. |
