SS Specific Service Issues/RepairsService/Repairs specific to the SS. Turbo-Brembo Brakes-2.0 Engine-Limited Slip Differential-Programmable Display-MU3 Transmission
I installed a set of KYB GR-2/Excel Gas shocks on the original springs on a 2009 HHR SS. I had no front end noise. Now when I make a fairly hard turn left or right I hear the coil spring slipping and making a clunking/grinding noise. I replaced the bearings, insulators, mounts,etc. With the weight off the front end there is no noise when turning. I was wondering do the springs and struts have to be positioned in a specific way!
I have removed the struts twice. Before I removed the struts I researched very carefully as always and I never found any information that mentioned lining up the tab so the first time I did not pay much attention to the placement of the tab. I recently removed the struts to replace the bearing plate because I thought that might be the problem and I did line up the tab but of course I do not know if the tab was oriented correctly. I did discover that the spring had been rubbing quite aggressively on the bearing plate side opposite of the tab but I had no noise until I replaced the shocks. What direction does the tab normally face.
You have the 2 isolaters, #4, that should keep the spring from contacting any other strut components. Not sure how your spring could rub on the bearing plate as you stated if that isolater is good and installed. Hope it's not an "OOP's" moment where you left the isolater out during reassembly. There are little indents on the plastic that line up with indent on the strut perch. The tail end of the spring fits into that indented part. (red arrows in picture)
And, I'm sure you know that those KYB struts are not an equal to the original FE5 struts that the HHR SS came with. They're going to be a little softer in the valving than the originals.
I replaced the insulators and with no weight on the vehicle there is no noise when turning. I purchased the shocks from ZZP and I was aware that they were a little softer but I really can not tell the difference. I ask ZZP if they had had any similar complaints and they said no but this does not make sense to me. I can not see where anything is now hitting. It is like the springs are building up twisting pressure and suddenly releasing. I found a picture of an OEM assembled strut where I can see the tab and I am going to try to make a comparison on the vehicle. Thanks.
I have ask just to verify something, did you disassemble both sides and possibly switch the springs or bearing plates from side to side?
the picture shows Cobalt , but HHR SS pictures are harder and harder to find.
Springs are the same part for both sides. Can go on either side.
But. There is a top and bottom to them. The springs must be installed "right side up". Any chance you got that side spring upside down ?
