Swapped rack and pinion/MEVOTECH TXES80479 the best?
My "cheapest rockauto FE5 rack and pinion" came in today. Got off work at 3:30 and was done with the swap by 7:30. even got food and beer first. Didn't have to remove the transmission mount, just rotated the metal band on the large end of the rack and pinion bellow and it slid in pretty easily.
I will post pics and video tomorrow, my phone is almost dead, and I left my battery charger at work.
The things that connect to the outer tie rod ends are completely loose. they just flop around with ZERO resistance. The new ones are hard to move. The outer tie rod ends rubber is broken and exposed. I did indeed find the culprit - the middle thing going up with the slot for the bolt, about 5" long - was super loose. I'm going to assume they never got an alignment and it just wore itself out over time.
Anyways, are the MEVOTECH TXES80479 on rock auto ($30 each) the best you can get?
https://www.rockauto.com/en/moreinfo...t=7428&jsn=933
I don't see a heart sign next to them (indicating a customer favorite)
The MOOGES800030
https://www.rockauto.com/en/moreinfo...t=7428&jsn=924
Has a heart next to it though.
Which ones should I get?
The MOOGES800030
Hard to say. One of their interchange numbers is correct for AU FE5
Supersession(s): 25956921
ROD KIT,STRG LNKG OTR TIE. Required: 02
For: AP37-69 (2009-2009) (2009 - 2009).
For: AU PERF & HANDLING SUSP(FE5) (2008-2010) (2008 - 2010).
But several other Interchange numbers seem to be incorrect.
Supersession(s): 15220347; 25956920; 15140337; 22664783; 22684863
Fits Cobalt, G5, HHR, Ion, Pursuit
3.4 LITER. Cobalt. COUPE,. Equinox, Torrent; 3.4L. G5. HHR; Soft Suspension. Ion. SEDAN,. Vue. W/o SS model.
So maybe it's one of those "Fits but isn't correct " . It's a Tie Rod End. You're probably not autocrossing, and even if you were, would it matter? Of course there are many "FE5" parts that do matter, but this might not(if it does "fit").
Like you said, be the guinea pig. Which is neither a pig, nor from Guinea, btw. Just a little useless factoid.
EDIT: whoops, I was looking at the Moog. The Mevotech doesn't show either of the FE5 numbers in the interchange list.
ROD KIT.
Part Number: 25842032Supersession(s): 25956921
Steering Tie Rod End
Part Number: 25956927Supersession(s): 15220347; 25956920; 15140337; 22664783; 22684863
