What size rims do I need?
I have a 2009 HHR SS with 225/45/18 tires. I'd like to go to a 16" rim for the winter. I'm dumb on this. I think I want 16" rims with a 5-110 bolt pattern but I didn't know I needed a width too. What width do I want & is the width the same for the 18" & 16" wheels? Thanks, Pam
Plug in your size and mine to see if they are the same diameter.
http://www.miata.net/garage/tirecalc.html
Wrong, 17" are the smallest with Brembo's, here's a link to Cobalts SS/TC site that list the rims known to fit with Brembo's (some require spacers), Cobalt SS/TC use the exact size, bolt pattern and backspacing. Not all HHR SS's had Brembo's.
http://www.cobaltss.net/forums/showthread.php?t=186349
Pam, I PM'd you on this before I saw the post, Do you know if you have the Brembo brakes (performance package) on your car? If not you can go to 16"s. 5 X 110mm bolt pattern, with a 42mm offset and 7 1/2" wide, You can go a little narrower on the width if you go with a narrower tire.
Not to bring an old thread back to life but with winter just around the corner and me being a n00b SS owner... I was curious to know something.
I have a '09 SS w/ Brembo's and want to but on some steelies and Blizzaks for winter.
What offset do I need exactly???
Lug Pattern - 5 x 110
Diameter - 17"
Offset - ????
+40mm???
Thanks in advance!
Diameter - 17"
Offset - ????
+40mm???
Thanks in advance!
