Wheel loose, shaking when not turning
So here is an interesting one I just noticed...
I have some play in the wheel when the car is stopped, and when I'm on the freeway, going straight there is a lot of wobble but if I turn at all, it immediately goes away. Starts about 55-65mph
I don't think it's a wheel bearing since I've done a few on my LT and there is no grinding noise.
Here is a video of the wheel while stopped. (Turn volume up a bit)
Anything you guys recommend I inspect first?
https://youtu.be/dhXxQ1KVMds
When was that wheel last removed and reinstalled? May have been installed incorrectly....."out of plumb". Wheel weight knocked off? Lug nuts not tightened correctly? Easy stuff first !!!
This is a common symptom of something loose. When you're going straight there is no load and loose things can vibrate, As soon as you turn the wheel, everything is suddenly under load and the vibration stops.
Where can I access the last 2 items?
If I swap front to back, would that eliminate the possibility? The front tires have some wear on the outside...same as my 2010 LT.
Makes sense. I am willing to check whatever is needed!
Where the LCA’s rear bolts torqued correctly, 74 ft lbs then 180 degrees tighter?
the steering shaft lives up under the dash above the pedals, the steering rack is on the subframe behind the engine
