Why so high final drive ratio?
Old May 11, 2011 | 05:18 AM
  #41
Holy tread resurrection, Moon...... This is from 2008???
Old May 11, 2011 | 11:32 PM
  #42
moonsign's Avatar
oops....my bad
Old May 11, 2011 | 11:52 PM
  #43
So 235 hp for (stock) auto SS huh ..
Old May 12, 2011 | 12:23 PM
  #44
asanti's Avatar
Yup, the GMTU brings that back up to 290hp, 315 lb/tq. though IIRC.
Here the link to the thread on that here: https://www.chevyhhr.net/forums/2-0l-performance-tech-46/gm-performance-parts-turbo-upgrade-kit-19891/
Later
Allex
Last edited by asanti; May 12, 2011 at 12:27 PM. Reason: corected GMTU hp/tq #'s and added linky.
Old May 12, 2011 | 01:06 PM
  #45
solman98's Avatar
Originally Posted by moonsign
I won't mention names, but some of you have your head way up, where the sun don't shine.
A SS 5sp manual vs a SS Auto, same HP, the auto will put the powder down, and consistantly better than a shifted SS. Shifting manually, I don't care how good you think you are, you will not and can not be consistant. A Auto takes almost all of the driver error[read "Rookie"] out of the equation. Unless they have raced for many years, and behind the same car, you will not shift at the right time, every time. Bottom line, 5 sp eats it-goes home.
Given the ratios stated for both the SS manual and the Auto, the Auto has a slight edge on the top end, no matter what you think. "Moon"
So back in 2008, the comments about the auto being detuned was correct.....
But since this did get brought back to life, when did the auto's final drive ratio change from 3.91 to 3.29 on the LS/LT's? I know a few (sleeper) has the 3.91 in his though.
Old May 12, 2011 | 10:45 PM
  #46
solman-
Good memory, yes my 08 has option FX2 = 3:91
& so does a friend that has an '09 2LT wagon, I saw his build sheet.
As to when it went to 3:29, IDK ??
Old May 12, 2011 | 11:21 PM
  #47
RFT's Avatar
RFT
Still think the OP has an interesting question.. regardless of what is faster, more mpg, etc, why do you have run at 2500 RPM at 65 in a 5sp versus approx 2100 in an auto? I know it would be nice if I could have an extra gear to go into when I'm at speed on the interstate - and I'm not talking 80 either, although it's only 5 over in area's I might drive.
RBodeman
Nov 16, 2012 07:09 PM
foofoomaru
Tires & Wheels
11
Feb 8, 2012 05:24 AM
1970judge
Oct 14, 2010 05:53 AM
Marcruger
Fuel Economy - Hypermiling
23
Jun 9, 2010 10:31 AM
Marzipan
Mar 19, 2008 11:25 PM
