WTF with my Turbo
Old Nov 2, 2010 | 08:36 AM
JeramieJJ's Avatar
Originally Posted by chevyman1976
the turbo shoots to 10 and flat lines there and suddenly WHAMO surges up to 20-21 and it takes off and the low traction flashes so I know it's putting down the power.
...if you can reach down there, take off the BOV (search there is a how to on the Dejon spring install that you can follow for removing it) and check the spring and rubber diaphragm. I would think the BOV is shot or possibly wastegate/solenoid could cause these symptoms. But I know for a fact the BOV is crap...have gone through 3 so far.
If the turbo was going, you would hear the bearings wine/grind....Mine went at 8K, so I know the sound. On the otherhand, maybe the turbo is cracked....causing these intermittent issues, but the over-boost doesn't make sense then.
Old Nov 2, 2010 | 09:22 AM
Hib Halverson's Avatar
I agree with "Jeramie JJ". If you feel it "sputtering" at WOT high rpm, it's either a waste gate or waste gate controller which is inconsistent causing varying levels of boost. It also could be knock retard being enabled because of detonation at 21 psi boost. And, of course, it could be misfire, as someone else on this thread suggested.
In any event, if you're seeing 21 psi boost from a engine with no mods, I'd address that problem.
87silver
Racing Discussion
0
Nov 29, 2010 08:01 PM
TurboTechRacing
2.0L Performance Tech
0
Oct 28, 2009 09:03 PM
Hotrodbob
May 8, 2008 01:06 AM
Lone Ranger
Feb 9, 2008 06:04 PM
