Turbo Tech Racing Releases Rear Sway Bar
just ordered a bar in black.....cant wait. ....question, there's a solid round "bar" up inside the V-beam rear "axle".......what is that bar all about...is it there just to provide a more rigid axle or is it a sway bar, as well ??....and, does the TTR 1" bar make contact with the V-beam axle..??
THat is the factory torsion/sway bar, it stays installed in there, dont remove it. Our bar is a "addition" to that.
When you get it, our bar will also go up in the "V" for maximum clearance. It does not cotact the "V" of the rear axle beam.
Turbo Tech Sway Bar
I ordered a red one, I received it a few days back and installed it today. Great fit. Nice packaging and instructions. Quick shipment. Excellent communication with vendor. (But I am still waiting to get the decals)
. The instuctions says to use a 15MM socket to bolt it on. Mine came with 17MM bolts.
Sway bar
Driving in a straight line, no difference.
But now I can push the SS around corners with more confidence. When I drive it hard around corners/curves is like a fast go-cart on rails. Love it
